abhishek x86_64-linux-gnu $ ls -l |grep libudev
lrwxrwxrwx 1 root root      34 Jun 27 15:11 libudev.so.0 -> /lib/x86_64-linux-gnu/libudev.so.1
lrwxrwxrwx 1 root root      16 May 12 15:09 libudev.so.1 -> libudev.so.1.6.4
-rw-r--r-- 1 root root  126840 May 12 15:09 libudev.so.1.6.4
abhishek x86_64-linux-gnu $ sudo dpkg -i ~/Downloads/reditr_amd64.deb                               [sudo] password for abhishek:
(Reading database ... 313009 files and directories currently installed.)
Preparing to unpack .../Downloads/reditr_amd64.deb ...
Unpacking reditr (3.0.0.0) over (3.0.0.0) ...
dpkg: dependency problems prevent configuration of reditr:
 reditr depends on libudev0 (>= 147); however:
  Package libudev0 is not installed.
dpkg: error processing package reditr (--install):
 dependency problems - leaving unconfigured
Processing triggers for man-db (2.7.5-1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu5) ...
Processing triggers for mime-support (3.59ubuntu1) ...
 reditr
abhishek x86_64-linux-gnu $ sudo apt-get install libudev0
Reading package lists... Done
Building dependency tree
Package libudev0 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libudev0' has no installation candidate
I am trying to install reditr, there is dependency of libudev0 which doesn't exits in repos. Following https://www.reddit.com/r/reditrbugs/comments/3lzmhq/bug_with_reditr_on_ubuntu_1504_libudev147/ I created a syslink, this doesn't work.
You can download libudev0 from:
http://packages.ubuntu.com/precise-updates/amd64/libudev0/download
And install it by: sudo dpkg -i libudev0[verion-and-stuff].deb
And then install reditr.deb
mlibre
  • 113
