I was upgrading from 15.10 to 16.04 and I got some prompts about config files having changed, e.g. /etc/xdg/autostart/at-spi-dbus-bus.desktop. So I type D to see the diff, but then accidentally hit ctrl+c (intending to copy out the diff) instead of ctrl+shift+c. Just a slip of the fingers.
Anyway, this promptly seemed to quit the upgrade process (although leaving the terminal in a weird state), but of course it wasn't finished installing! Although running sudo do-release-upgrade gives
No new release found. How do I get back into the installation process? I can tell dpkg is running because it's locked. sudo lsof /var/lib/dpkg/lock yields:
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
dpkg 29329 root 3uW REG 8,7 0 262367 /var/lib/dpkg/lock
I'm worried now that if I restart my computer, it won't boot up at that point, and I'm hoping there's a way to resume installation without having to reboot into recovery mode etc. Kind of annoyed too that it quit so easily by pressing ctrl+c.
One option of course, as described here, is to kill my dpkg process then try running sudo dpkg --configure -a... but I figured I'd ask here if there are any ideas before I do something that could be irreversible.
Alternatively, if someone knows that the specific stage I stopped at (config files) is early enough that it's nbd, that would also be helpful!
