I was trying to install ubuntu on an external hard drive using my dads dell laptop because my laptop was being repaired. Anyways i used a bootable iso usb from unetbootin to install it. I have done this before with a dvd and it worked fine and this time i did the same thing. Windows is on the internal hard drive. When it finished, it told me to reboot and when it rebooted it went to a grub command prompt.So now whenever the computer boots up you have to press F12 and then it brings you to a boot menu. The boot menu says option 1 ubuntu option 2 windows option 3 ubuntu. Im guessing the first ubuntu boot option is the grub command prompt. I dont know what the last ubuntu boot option does because i dont want to boot it because it might mess something up. My dad is annoied about how he has to do the whole F12 thing every time he starts up his computer. Is there anyway i can change the boot order, remove ubuntu all togethor, or do something else to make the laptop boot up right into windows. Thank You.
You can use Windows' built in tools to fix it.
Follow the steps under Fix the MBR in Windows 7 or Fix the MBR in Windows 8 or 8.1 here
You probably only need to run "bootrec /fixmbr" and "bootrec /fixboot"
Windows 7
  1. Boot from the Windows 7 installation DVD
  2. At the “Press any key to boot from CD or DVD…”, press any key to boot from the DVD
  3. Select a language
  4. Select a keyboard layout
  5. Click Next
  6. Select the operating system and click Next. The “Use recovery tools that can help fix problems starting Windows” must be checked when you select the operating system.
  7. At the System Recovery Options screen, click on Command Prompt
  8. When Command Prompt successfully loads, type this command:
    bootrec /rebuildbcd
  9. Press Enter Type the next command:
    bootrec /fixmbr
  10. Press Enter Type the next command:
    bootrec /fixboot
  11. Press Enter
  12. Remove the installation DVD from the disk tray and restart your computer
Fix the MBR in Windows 8 or 8.1 (also 10)
  1. Boot from the original installation DVD (or the recovery USB)
  2. At the Welcome screen, click Repair your computer
  3. Choose Troubleshoot
  4. Choose Command Prompt
    When the Command Prompt loads, type the following commands:
    bootrec /FixMbr
    bootrec /FixBoot
    bootrec /ScanOs
    bootrec /RebuildBcd
Press Enter after each command and wait for each operation to finish
  1. Remove the DVD from the disk tray
  2. Type exit
  3. Hit Enter
  4. Restart your computer and check if Windows 8/8.1 can now boot
Curtis
  • 156
what worked for me was booting up a live cd and then deleting the ubuntu entry from the efi partition.
