I have installed Ubuntu 14.04 on my 16 gb usb drive.When i connect it to my laptop it boot properly and i can use,update and install any package on usb drive.But when i connect to other computer it cant boot.
Asked
Active
Viewed 47 times
This is likely due to the fact the bootloader was installed to the hard drive of the system and not to the usb.
Open a terminal, and type sudo fdisk -l (your USB flash drive should show up in the list if it is inserted). Now, type sudo grub-install /dev/<insert usb drive name here> to install it on your usb drive.
for example:
sudo grub-install /dev/ubuntuusb
If you labelled your usb device ubuntuusb. Be careful to select the right device or you could inadvertantly destroy another operating systems bootloader. Hope this helps.
Matt
- 46
- 4
