UPDATE
BIOS allows for booting from SD card slot, a program like Unetbootin can be used to configure a bootable SD card Ubuntu installer. lubuntu 16.04 failed to install, whereas 15.10 was successful. Decided on Xubuntu 16.04
ORIGINAL POST
If you have had success installing Ubuntu on the 1000HE: please state this in the first sentence of your response.
I was unable to boot from USB so I have a few questions. I tinkered with the BIOS settings (per youTube and other websites) and only the SATA HDD would show up as a bootable device option. ESC lists boot options.
Questions:
1) Is it possible to boot from USB? Maybe I missed a step. Bonus if you successfully performed this and reply with the specifics of the procedure.
2) What sacrifices / shortcoming should be expected with Ubuntu that are specific to the 1000HE?
3) Is there a technique to configure a SATA drive with another PC to install Ubuntu? The drive would be configured as bootable and the 1000HE would boot the drive and Ubuntu would configure itself. Maybe a transplant from another donor Ubuntu PC?
I found this link regarding Ubuntu and the 1000HE but the issues was with Ubuntu 9.04 in 2009. I look-forward to a post indicating success and pitfalls to avoid. Thanks
gatorback
  • 6,523
I've installed Ubuntu on an EEE 1015PX with no major hurdles.
  1. Where the USB drive won't show in boot device selection:
    • Confirm the drive is bootable on another computer
    • Read the computer's manual, or look through the BIOS settings, for any info about "boot from USB"
  2. Nothing specific, just don't expect the thing to be fast, since it's a 7-year old netbook. For that reason, you'll probably want to install a lighter flavour like Lubuntu.
  3. This answer says you can install Ubuntu on another computer, and just swap the drive - nothing too complicated. Just make sure you install the right architecture for the receiving computer. I suggest 32bit because the machine is older and only has 1GB of RAM.
wjandrea
  • 14,504
