I recently got a HP Envy 15 ah150na laptop with an AMD A10 8700p CPU and and R6 8700p integrated graphics card. The problem is that the CPU temperature after 10-15 minutes of usage goes up to around 60C and does not really go down at all. I'm not entirely sure if the CPU or the GPU is to blame. The GPU itself uses the amdgpu driver from the oibaf PPA.
I'm running kernel version 4.6 on Ubuntu 16.04.
TLP with the default configuration is installed as well.
Any help would be much appreciated.
Edit: Forgot to mention that the temperature is much lower on Windows 10 which came pre-installed. Also forgot to mention that changing the stock thermal paste (terribly applied) helped to shave off 5-10 degrees but it was not really enough. Also for some reason indicator-cpufreq doesn't seem to work at all.
