I am attempting to use a third-party C library. Once I'm in the directory for the unpacked file I run ./configure and get:
configure: creating ./config.status
config.status: creating tests/Makefile
config.status: creating tests/atlocal
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating igraph.pc
config.status: creating igraph_Info.plist
config.status: creating doc/Makefile
config.status: creating include/igraph_version.h
config.status: creating include/igraph_threading.h
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing tests/atconfig commands
config.status: executing depfiles commands
config.status: executing libtool commands
igraph successfully configured.
GraphML format support -- no
GMP library support -- no
GLPK library support -- yes
Thread-local storage -- yes
Use internal ARPACK -- yes
Use internal LAPACK -- yes
Use internal BLAS -- yes
Use internal F2C -- yes
Use internal GLPK -- yes
Debug build -- no
Profiling -- no
I then run "sudo make" and get:
collect2: error: ld returned 1 exit status
Makefile:2357: recipe for target 'libigraph.la' failed
make[3]: *** [libigraph.la] Error 1
make[3]: Leaving directory '/home/jiggly/Documents/igraph-0.7.1/src'
Makefile:1377: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/home/jiggly/Documents/igraph-0.7.1/src'
Makefile:480: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/jiggly/Documents/igraph-0.7.1'
Makefile:382: recipe for target 'all' failed
make: *** [all] Error 2
I have also tried sudo checkinstall and get:
make[2]: *** [libigraph.la] Error 1
Makefile:7813: recipe for target 'install' failed
make[1]: *** [install] Error 2
make[1]: Leaving directory '/home/jiggly/Documents/igraph-0.7.1/src'
Makefile:480: recipe for target 'install-recursive' failed
make: *** [install-recursive] Error 1
**** Installation failed. Aborting package creation.
Restoring overwritten files from backup...OK
Cleaning up...OK
Bye.
I get the same errors when I specify a prefix for ./config
