I have a system here where I set a an idle (low-power) timeout for one hard-drive, as it is not used that much. For this, I have the command hdparm -S6 /dev/sdc in /etc/rc.local.
However, I've found that this works well over boots, but when I send the machine into hibernation/suspend and resume, the hard-drive remains powered up; the hdparm setting doesn't "stick". My workaround, which is getting on my nerves, is to issue the command manually again when I resume from hibernation.
Which script/file, like rc.local, is executed after suspend?
isync
  • 664
This doesn't work:
nano /etc/pm/sleep.d/myself_hdparm
which contains:
#!/bin/sh
case "$1" in
    resume)
        echo "setting sdc to low-power idling mode after resume!"
        hdparm -S6 /dev/sdc
esac
and then:
sudo chown myself:myself /etc/pm/sleep.d/myself_hdparm
sudo chmod 0755 /etc/pm/sleep.d/myself_hdparm
isync
  • 664
I do not have this resume-and-forget issue when I configure the value in /etc/hdparm.conf under "apm = " Values depend on distro afaik. However, the hdparm man page gives you the values that should work.
opinion_no9
  • 1,072
As it seems, the proper way to do it (at least with Ubuntu 14.04 and up) is to use gnome-disk-utility:
  1. Select the disk in question
  2. Click the little gear icon in the upper right corner of the disk utility app-window (not the gears on the partition, but on the application-window itself). It's a "hamburger button" on 18.04. Keyboard shortcut is "E".
  3. Select drive settings
  4. (a number of tabs shows up, depending on your drives capabilities)
  5. Select either the standby, APM or AAM tab
  6. Adjust settings to your liking
If anyone knows how this works under the hood, if there's some daemon involved in managing drives or so, please post a comment.
isync
  • 664
