14
I accidentally deleted /var/log/syslog and now I can't get rsyslog working.
I was googling, I tried everything I found. To be precise:
I created syslog with touch.
Then I set chmod and chown correctly. Now ls -al gives this result:
-rw-r-----  1 syslog            adm           0 jún   23 02:36 syslog
-rw-r-----  1 syslog            adm     1557257 jún   23 01:33 syslog.1
-rw-r-----  1 syslog            adm      156618 jún   22 07:51 syslog.2.gz
-rw-r-----  1 syslog            adm      155851 jún   21 07:45 syslog.3.gz
-rw-r-----  1 syslog            adm      155199 jún   20 07:35 syslog.4.gz
-rw-r-----  1 syslog            adm      159709 jún   19 07:37 syslog.5.gz
-rw-r-----  1 syslog            adm      156035 jún   18 07:52 syslog.6.gz
-rw-r-----  1 syslog            adm      158478 jún   17 07:55 syslog.7.gz
Then I restarted rsyslog service:
service rsyslog restart
I rebooted the system several times.
I even re-installed rsyslog with apt-get purge and apt-get install
But none of these helped me. As you can see above, syslog still has a length of 0 bytes, nothing gets logged.
Edit:
Even when I'm trying to log something manually, nothing gets logged:
# ls -al /var/log/syslog
-rw-r----- 1 syslog adm 0 jún   23 14:04 /var/log/syslog
# logger "this message should end up in syslog"
Permissions of /var and /var/log:
# ls -al /var
drwxr-xr-x 14 root root     4096 dec   16  2015 .
drwxr-xr-x 24 root root     4096 máj   31 14:14 ..
drw-rw---- 22 root syslog   4096 jún   23 14:05 log
I'm on ubuntu 14.04
balping
  • 453
As @Rinzwind pointed out: the permissions on the /var/log directory may have accidentally been changed. In a fresh install they are drwxrwxr-x.
Change your permissions:
# chmod 775 /var/log
and # systemctl restart rsyslog (or reboot). Test the syslog facility with:
$ logger "this message should end up in syslog"
Giszmo
  • 165
Jos
  • 30,529
  • 89
  • 96
Same problem with server Ubuntu 16.04 LTS. I deleted /var/log/syslog.
Problem is the OWNER / Group of the syslog file !
Solution :
  1. create an empty syslog file
  2. With Ubuntu 16.04, the owner group must be syslog:adm
  3. restart
  4. test with logger
Commands:
cd /var/log
touch syslog
chown syslog:adm syslog
logger "Didier MISSON logger test"
You must see the message in the syslog:
less syslog
David Foerster
  • 36,890
  • 56
  • 97
  • 151
