I don't have a clue about how to install the latest stable version of wkhtmltopdf. When I download and uncompress the tar.xz I get four folders:
  • lib
  • bin
  • include
  • share
What should I do with this files?
MikeVelazco
  • 103
You can install it without that files, just open terminal and run:
sudo apt-get install wkhtmltopdf
Then use it from the command line like:
wkhtmltopdf example.org
wkhtmltoimage example.org
Or you can copy the files you've downloaded to /usr folder using your window manager or running sudo mv * /usr from in the directory you uncompressed the tar.xz file.
Or you can run the file from where you extracted them using:
chmod -R u+x /extracted/path
./extracted/path/bin/wkhtmltopdf <arguments>
Cheers.
razorx
  • 441
The wkhtmltopdf binary is found in the bin/ directory ("bin" stands for binaries). Therefore, to run it in the terminal, cd to bin/ and run ./wkhtmltopdf with appropriate arguments.
edwinksl
  • 24,109
