I am using Terminator, because it has cool ability to split itself into more terminals. But can it be run as root, without need to type sudo -i after launch? (adding Run as root into Terminator shell for example)
Asked
Active
Viewed 3,660 times
PKM
- 839
Copy the .desktop file from /usr/share/applications (or just add it to desktop and then create a copy) so that you don't have to edit all from the start and then:
First option
Change the
Exec=line to:Exec=terminator -e "sudo -i"This will ask for your password when you open terminator.
Second option
Install
gksu(sudo apt-get install gksu) and change theExec=line to:Exec=gksu terminatorThis will open a pop up which will ask you your password and give you a root terminator without any user preferences though.
NOTE: Never run sudo terminator because it might change the user folder ownership or cause other problems, always use gksu for gui applications.
Thanos Apostolou
- 4,501
