i have the same issue as this old thread "MySQL error: The partition with /var/lib/mysql is too full!" but the answer offered is not working for me (which is to do a sudo mysql stop & a sudo mysql start)
To resume, when i try to restart mysql, i have the error :
Permission Denied
but when i use the command df, here is what i got
Filesystem Size Used Avail Use% Mounted on
udev 1,9G 4,0K 1,9G 1% /dev
tmpfs 387M 1,5M 385M 1% /run
/dev/sda2 913G 15G 852G 2% /
none 4,0K 0 4,0K 0% /sys/fs/cgroup
none 5,0M 0 5,0M 0% /run/lock
none 1,9G 54M 1,9G 3% /run/shm
none 100M 12K 100M 1% /run/user
/dev/sda1 511M 3,4M 508M 1% /boot/efi
and here is the answer i get from df -i when i am in the folder
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 490671 533 490138 1% /dev
tmpfs 494563 604 493959 1% /run
/dev/sda2 60760064 283468 60476596 1% /
none 494563 2 494561 1% /sys/fs/cgroup
none 494563 3 494560 1% /run/lock
none 494563 60 494503 1% /run/shm
none 494563 17 494546 1% /run/user
/dev/sda1 0 0 0 - /boot/efi
and when i just do df -i /var/lib/mysql
/dev/sda2 60760064 284097 60475967 1% /
I don't know if i am missing something but to me this is not full, i tried apt-get clean, it worked and then the issue is back as soon as the system start again. Also, rebooting didn't help.
So if anyone has some idea, i would appreciate it, thanks
