I have a shell script using some sudo command. When I run this script from terminal - it asks me for password and runs with any problem. But when I try to run executable shell script form GUI (double click) it does not ask me for password - so does not work.
Example of my shell script:
c1=$(dmidecode -t 4 | grep ID | sed 's/.*ID://;s/ //g' | sha1sum | awk '{print $1}')
How to run script from GUI and pass all sudo commands with no problem?
muru
  • 207,228
Geroge
  • 123
You can pass the password to sudo from the standard input, like this:
echo 'yourpassword' | sudo -S yourcommand
Using -S tells sudo to read the password from stdin, which comes from the echo 'yourpassword' bit.
You could also edit visudo, so that sudo will never prompt for the password, either only for your specific comand, or always.
Warning: storing your password in plain text is an extremely bad idea
Jonas Czech
  • 4,047
