24
I am a complete noob at linux but I am starting to get the hang of it. I have an Ubuntu Server 16.04 running an FTP server to backup security video files. The files will be stored in folders like: /home/securityfolder1, /home/securityfolder2, /home/securityfolder3 and so on.
Note that each securityfolderN is a different user.
Because I don't want my hard drives to be full all of the time, I want to delete files older than 7 days in these folders daily.
terdon
  • 104,119
Jacco
  • 341
First, this command will find and delete all files older than 7 days in any subdirectory in /home whose name starts with securityuser:
find /home/securityuser* -mtime +6 -type f -delete
You need -mtime +6 and not +7 because -mtime counts 24h periods. As explained in the -atime section of man find (-mtime works in the same way):
   -atime n
          File  was  last  accessed n*24 hours ago.  When find figures out
          how many 24-hour periods ago the file  was  last  accessed,  any
          fractional part is ignored, so to match -atime +1, a file has to
          have been accessed at least two days ago.
So, to find a file that was modified 7 or more days ago, you need to find files that were modified more than 6 days ago, hence -mtime +6.
The next step is to have this command run once a day. Since each securityuserN is a different user (you might want to rethink that setup, it makes everything more complicated), this must be run as root. So, edit /etc/crontab:
sudo nano /etc/crontab
And add this line:
@daily root find /home/securityuser* -mtime +6 -type f -delete
That will run the find command once a day and delete the files.
terdon
  • 104,119
as per i my knowledge:
try find command like this:
find ./dirc/* -mtime +6 -type f -delete
./dirc/* : is your directory (Path)
-mtime +6 : modified more than 6 days ago (therefore, at least 7 days ago)
-type f : only files
-delete : no surprise. Remove it to test before like rm
terdon
  • 104,119
