I am very fresh in Linux. I tried to use the sudo apt-get command to install both wget and curl utilities. To do that I ran at the following CLI commands:
sudo apt-get curl
sudo apt-get wget
Both inputs give the error Invalid operation; No further information is given.
I tried to do man invalid || man Invalid, but there seem to be no entries for these terms.
Google search yielded zero results for "sudo apt-get wget" + "invalid operation".
For curl problem I did found a solution here but I would humbly prefer having an expert's take on this before trying it (as I really need wget as well and want to understand the root of the problem).
That's because apt-get does not have any option like curl or wget.
Perhaps you wanted to install/upgrade the packages, if so then:
sudo apt-get install wget
sudo apt-get install curl
The package name goes as argument to apt-get's option e.g. install, remove etc.
heemayl
  • 93,925
