I was messing around with Compiz Settings Manager and result of that is that I cant see my panel bar, cant use alt+tab or start button. Is there a way to restore default Ubuntu environment? I will be grateful for your help
Asked
Active
Viewed 8.7k times
14
In terminal, type in sudo apt-get install --reinstall ubuntu-desktop to completely reinstall back to defaults.
To remove all compiz settings type rm -rf ~/.compiz-1 ~/.config/compiz-1 in terminal, then logout and back in.
Delorean
- 11,563
Or you can install "Unity Tweak Tool" and set the default settings. Open a terminal and type:
sudo apt update
sudo apt install unity-tweak-tool
Nick Weinberg
- 4,636
Ahmed Mjadi
- 21
-1
Try the following, open terminal and type:
unity-reset
Alternatively:
setsid unity
But, If you can't get to the terminal cause your start buttons doesn't work you can always (this only works if you have a folder on the desktop) open the folder then go to 'computer>usr>share>applications' look for terminal inside the folder and click to open, then enter either of the above commands in the terminal.
wblm
- 357
