Idk why, i cant update my gcc
root@server:~# gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.8/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.8.4-2ubuntu1~14.04.1' --with-bugurl=file:///usr/share/doc/gcc-4.8/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.8 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.8 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libmudflap --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.8-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.1)
try command
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update
sudo apt-get install g++-4.9
have log:
root@server:~# sudo add-apt-repository ppa:ubuntu-toolchain-r/test
 Toolchain test builds; see https://wiki.ubuntu.com/ToolChain
 More info: https://launchpad.net/~ubuntu-toolchain-r/+archive/ubuntu/test
Press [ENTER] to continue or ctrl-c to cancel adding it
gpg: keyring `/tmp/tmpi_ap8pke/secring.gpg' created
gpg: keyring `/tmp/tmpi_ap8pke/pubring.gpg' created
gpg: requesting key BA9EF27F from hkp server keyserver.ubuntu.com
gpg: /tmp/tmpi_ap8pke/trustdb.gpg: trustdb created
gpg: key BA9EF27F: public key "Launchpad Toolchain builds" imported
gpg: Total number processed: 1
gpg:               imported: 1  (RSA: 1)
OK
root@server:~# sudo apt-get update
Hit http://security.ubuntu.com trusty-security InRelease
Ign http://archive.ubuntu.com trusty InRelease
Ign http://archive.canonical.com trusty InRelease
Get:1 http://ppa.launchpad.net trusty InRelease [15.5 kB]
Get:2 http://security.ubuntu.com trusty-security/main amd64 Packages [493 kB]
Hit http://archive.ubuntu.com trusty-updates InRelease
Get:3 http://archive.canonical.com trusty Release.gpg [933 B]
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?
root@server:~# sudo apt-get install g++-4.9
Reading package lists... Done
Building dependency tree
E: Unable to locate package g++-4.9
E: Couldn't find any package by regex 'g++-4.9'
root@server:~#
Check again gcc ver.
COLLECT_GCC=gcc
Thread model: posix
root@server:~#
The toolchain repository requires https access, so because of the error
your package catalogue is not being updated even though you have successfully added the repository.
You can find some suggestions to fix the error at “method driver /usr/lib/apt/methods/https could not be found” update error - if you're lucky (meaning that plain http method is not also broken) it should be as simple as installing - or possibly reinstalling - the relevant package
sudo apt-get install apt-transport-https
steeldriver
  • 142,475
