I'm currently experiencing a bit of lag on 720 HD videos. I am hoping VDPAU will help. How do I enable it on either GStreamer-based video players?
Asked
Active
Viewed 1.6k times
VDPAU is enable by default on the official nVidia binaries. If your card supports VDPAU you just need to install them and use a player that supports VDPAU.
Other then that video hardware acceleration should be implemented via libva if the vdpau-va-driver is installed.
sudo apt-get install libva1 vdpau-va-driver vainfo
Gstreamer should take care of the rest or if you are going to use a player like vlc you should have an option that enables that in the player it self.
To see if your card is supported run the command vainfo.
If you get an output like this
libva: libva version 0.32.0
libva: va_getDriverName() returns 0
libva: Trying to open /usr/lib/dri/vboxvideo_drv_video.so
libva: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exit
you card has no hardware acceleration.
If on the other hand you get something like this
Xlib: extension "XFree86-DRI" missing on display ":0.0".
libva: Trying to open /usr/lib/dri/fglrx_drv_video.so
libva: va_openDriver() returns 0
vainfo: VA API version: 0.32
vainfo: Driver version: Splitted-Desktop Systems XvBA backend for VA-API - 0.7.8
vainfo: Supported profile and entrypoints
VAProfileH264High : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
your hardware supports video acceleration and its enabled.
Bruno Pereira
- 74,715
