I get the following errors while trying to install ownCloud:
The following packages have unmet dependencies:  owncloud : Depends:
owncloud-server (= 8.1.8-12.1) but it is not going to be installed
            Recommends: mysql-server but it is not installable or
                        mariadb-server but it is not installable
            Recommends: exim4 but it is not installable or
                        mail-transport-agent but it is not installable
            Recommends: owncloud-config-apache (= 8.1.8-12.1) but it is not
E: Unable to correct problems, you haveheld broken packages.
How do I fix this?
andrew.46
  • 39,359
There is a fork of Owncloud called Nextcloud, and it is the version that is better supported. I recommend to use Nextcloud instead.
In Ubuntu 16.04 you can install Nextcloud as a snap (the new type of installation packages for Ubuntu 16.04 or newer).
The full documentation on how to try the snap edition of Nextcloud can be found at https://github.com/nextcloud/nextcloud-snap
user4124
  • 9,241
Do the following in terminal:
sudo dpkg --configure -a
sudo apt-get autoremove --purge
sudo apt-get autoclean --purge
sudo apt-get -f install
sudo apt-get update
sudo apt-get ugrade
sudo apt-get dist-upgrade
Hopefully now the dependency problem will get resolved
Now to install owncloud type in terminal
wget -nv https://download.owncloud.org/download/repositories/stable/Ubuntu_16.04/Release.key -O Release.key
apt-key add - < Release.key
sh -c "echo 'deb http://download.owncloud.org/download/repositories/stable/Ubuntu_16.04/ /' >> /etc/apt/sources.list.d/owncloud.list"
apt-get update
apt-get install owncloud
To install owncloud files type in terminal
apt-get update
apt-get install owncloud-files
NOTE: This will only work in Ubuntu 16.04
For Ubuntu 15.10
To install owncloud type in terminal
wget -nv https://download.owncloud.org/download/repositories/stable/Ubuntu_15.10/Release.key -O Release.key
sh -c "echo 'deb http://download.owncloud.org/download/repositories/stable/Ubuntu_15.10/ /' >> /etc/apt/sources.list.d/owncloud.list"
apt-get update
To install owncloud files type:
apt-get update
For Ubuntu 14.04
wget -nv https://download.owncloud.org/download/repositories/stable/Ubuntu_14.04/Release.key -O Release.key
sh -c "echo 'deb http://download.owncloud.org/download/repositories/stable/Ubuntu_14.04/ /' >> /etc/apt/sources.list.d/owncloud.list"
apt-get update
To install owncloud-files type:
apt-get update
In Ubuntu 12.04
wget -nv https://download.owncloud.org/download/repositories/stable/Ubuntu_12.04/Release.key -O Release.key
sh -c "echo 'deb http://download.owncloud.org/download/repositories/stable/Ubuntu_12.04/ /' >> /etc/apt/sources.list.d/owncloud.list"
apt-get update
apt-get update
user4124
  • 9,241
rancho
  • 4,136
