This is my first time doing anything like this but I really need my computer back so it here goes. The other day my computer froze so I had to unplug it and replug it however after I did so instead of going to the login screen I had this pink screen with the words GNU GRUB at the top and with the three options:
Advanced options for Ubuntu
Memory test (memtest86)
Memory test (memtest86+, serial console 115200)
And if I don't click any of them in time it goes to this strange screen with a ton of numbers on it and I could not get out of that screen unless I unplug. Please help me if you can I have no idea what to do.
muru
  • 207,228
Boot from a live usb
Go to terminal and type
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
sudo reboot
Now try normal login. Hopefully everything will work fine now.
rancho
  • 4,136
Try selecting "Advanced options for Ubuntu", and hopefully you should see a selection of older Ubuntu kernels. Select the newest version. If you're able to boot, open a terminal window and type: sudo update-grub, then enter your password. Reboot the computer, and you might be fine again.
heynnema
  • 73,649
