I tried to install nginx and PHP7 with FPM using this tutorial: https://www.digitalocean.com/community/tutorials/how-to-upgrade-to-php-7-on-ubuntu-14-04
When I try to access any .php file I get 502 Bad Gateway. When I try to restart php7.0-fpm, I get this:
sudo service php7.0-fpm restart
stop: Unknown instance:
php7.0-fpm start/running, process 5379
My nginx config:
location ~ \.php$ {
    try_files $uri =404;
    fastcgi_split_path_info ^(.+\.php)(/.+)$;
    fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
    fastcgi_index index.php;
    fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
    include fastcgi_params;
My server is Ubuntu Server 14.04
sotirov
  • 4,379
Try to check your nginx's www.conf file and make sure the socket path is correct and socket file is present at that location while these services are running.
ie, /var/run/php/php7.0-fpm.sock or
/dev/shm/php-fpm-www.sock
try to start php-fpm from init.d
/etc/init.d/php-7.0.0-fpm start
and check your php.ini file also
add the following to the end of the file
[apc]
apc.write_lock = 1
apc.slam_defense = 0
It is likely that an older libpcre3 is installed and satisfies the dependency in the php7.0 package, but only the newer library package provides pcre_jit_stack_free.
If this is the case, do an apt-get install libpcre3, and you’re good to go.
Ref.: https://github.com/oerdnj/deb.sury.org/issues/372
I'd literally been fighting this for days, when I found the solution. It was a typo in /etc/nginx/sites-available/www (copied originally from ...sites-available/default and modified).
I'd overlooked this in both the file itself and the /var/log/nginx/error.log --even though the error log was clear
connect to unix: /var/run/php/php7.0-fpm-sock failed (2: No such file or directory)
The connection line should have read unix: /var/run/php/php7.0-fpm.sock.
Duh.
Zanna
  • 72,312
I installed from a guide which used php7.0-fpm-sock ,which I copied pasted into nginx.conf. Making the change to php7.2-fpm-sock solved the issue for me. Would have commented, but i can't do that yet.
uberdave
  • 131
