I've tried using
sudo apt-get remove amazon
and the result was sudo-apt-get: command not found
and I tried
sudo apt-get remove amazon*
and I got
Reading package lists... Done
Building dependency tree
Note, selecting 'unity-webapps-amazoncloudreader' for regex 'amazon*'
Note, selecting 'ruby-amazon-ec2' for regex 'amazon*'
Note, selecting 'libnet-amazon-s3-tools-perl' for regex 'amazon*'
Note, selecting 'unity-webapps-amazon' for regex 'amazon*'
Note, selecting 'libnet-amazon-ec2-perl' for regex 'amazon*'
Note, selecting 'gamazons' for regex 'amazon*'
Note, selecting 'libnet-amazon-perl' for regex 'amazon*'
Note, selecting 'libamazon-sqs-simple-perl' for regex 'amazon*'
Note, selecting 'libnet-amazon-s3-perl' for regex 'amazon*'
Note, selecting 'flight-of-the-amazon-queen' for regex 'amazon*'
Note, selecting 'gmpc-plugin-coveramazon' for regex 'amazon*'
Package 'unity-webapps-amazon' is not installed, so not removed
Package 'gmpc-plugin-coveramazon' is not installed, so not removed
Package 'flight-of-the-amazon-queen' is not installed, so not removed
Package 'gamazons' is not installed, so not removed
Package 'libamazon-sqs-simple-perl' is not installed, so not removed
Package 'libnet-amazon-ec2-perl' is not installed, so not removed
Package 'libnet-amazon-perl' is not installed, so not removed
Package 'libnet-amazon-s3-perl' is not installed, so not removed
Package 'libnet-amazon-s3-tools-perl' is not installed, so not removed
Package 'ruby-amazon-ec2' is not installed, so not removed
Package 'unity-webapps-amazoncloudreader' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 18 not upgraded.
How can I remove this amazon application that was installed by default?
Videonauth
  • 33,815
Try this:
sudo apt-get remove unity-webapps-common
muru
  • 207,228
Why this throws errors
sudo-apt-get remove amazon
The problem here is multiple
  • its sudo apt-get remove PACKAGENAME not sudo-apt get PACKAGENAME
  • You are guessing PACKAGENAMES (amazon) here
How to locate package names and remove them
I would recommend to check what packagename you need to remove first and then remove it.
You could filter all installed packagenames for the string amazon first like this
sudo dpkg -l | grep amazon
This should output all installed package-names containing the string amazon.
Then - if you know which packagename you want to remove do as follows
or
sudo apt remove PACKAGENAME
As @Saikat Kundu mentioned already - the packagename you are looking in this particular case is unity-webapps-common.
Hope this helps understanding apt
dufte
  • 14,198
  • 41
  • 43
