Situation
I have installed a number of programs in a libertine container - some via the libertine command, and some by 'apt get' after entering the container.
It seems that many of them are not properly conifgured - or that dependencies are not configured.
Symptoms
This is what I see if I try to install something in the container with apt-get:
After this operation, 0 B of additional disk space will be used.
Setting up x11-common (1:7.7+7ubuntu4) ...
open: No such file or directory
dpkg: error processing package x11-common (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of libice6:armhf:
 libice6:armhf depends on x11-common; however:
  Package x11-common is not configured yet.
dpkg: error processing package libice6:armhf (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libsm6:armhf:
 libsm6:armhf depends on libice6 (>= 1:1.0.0); however:
  Package libice6:armhf is not configured yet.
dpkg: error processing package libsm6:armhf (--configure):
dpkg: dependency problems prevent configuration of libxt6:armhf:
 libxt6:armhf depends on libice6 (>= 1:1.0.0); however:
 libxt6:armhf depends on libsm6; however:
  Package libsm6:armhf is not configured yet.
dpkg: error processing package libxt6:armhf (--configure):
Setting up isc-dhcp-client (4.3.1-5ubuntu2.3) ...
mktemp: failed to create file via template ‘/run/user/32011/confined/com.ubuntu.terminal/tmp.XXXXXXXXXX’: No such file or directory
dpkg: error processing package isc-dhcp-client (--configure):
Setting up ca-certificates (20141019ubuntu0.15.04.1) ...
Setting up dictionaries-common (1.23.17) ...
dpkg: dependency problems prevent configuration of ghostscript-x:
 ghostscript-x depends on libxt6; however:
  Package libxt6:armhf is not configured yet.
dpkg: error processing package ghostscript-x (--configure):
dpkg: dependency problems prevent configuration of transfig:
 transfig depends on x11-common; however:
dpkg: error processing package transfig (--configure):
dpkg: dependency problems prevent configuration of xournal:
 xournal depends on ghostscript-x; however:
  Package ghostscript-x is not configured yet.
dpkg: error processing package xournal (--configure):
Processing triggers for ca-certificates (20141019ubuntu0.15.04.1) ...
mktemp: failed to create file via template ‘/run/user/32011/confined/com.ubuntu.terminal/ca-certificates.crt.tmp.XXXXXX’: No such file or directory
dpkg: error processing package ca-certificates (--configure):
Processing triggers for dictionaries-common (1.23.17) ...
mktemp: failed to create directory via template ‘/run/user/32011/confined/com.ubuntu.terminal/ispell-auto.XXXXXXXXXX’: No such file or directory
ispell-autobuildhash: Cannot make temporary directory under "/run/user/32011/confined/com.ubuntu.terminal". Aborting ...
update-default-ispell: Error running ispell-autobuildhash
dpkg: error processing package dictionaries-common (--configure):
 subprocess installed post-installation script returned error exit status 25
 x11-common
 libice6:armhf
 libsm6:armhf
 libxt6:armhf
 isc-dhcp-client
 ghostscript-x
 transfig
 xournal
 ca-certificates
 dictionaries-common
full output here : https://paste.ubuntu.com/17474260/
I'm not sure if the output is always important. Xournal is flagged as not being installed correctly but it does work.
Question
Could anyone shed some light on this? Is it something that can be corrected?
Jack
  • 532
This is a recurring problem if you try to set up a Libertine container from the Terminal App, and caused by the confinement of the Terminal App.
Please try again using an ssh or adb shell session, which is fully unconfined.
A better long-term solution for this problem is under development but unlikely to be delivered before OTA-13.
