While attempting to scan with simple-scan, I very often (but not always!) get an I/O error telling me that the scanner is unreachable. I don't think it's a physical connection issue (cable or USB port problem), because printing with the same device works without problems.
I'm using Ubuntu 16.4. and my device is Samsung SCX-3205W. I have installed the newest drivers from the producer website.
Here is the console output of simple-scan:
$ simple-scan -d
[+0,00s] DEBUG: simple-scan.vala:674: Starting Simple Scan 3.20.0, PID=3395
[+0,00s] DEBUG: Connecting to session manager
[+0,08s] DEBUG: ui.vala:2032: Loading state from /home/ja/.cache/simple-scan/state
[+0,08s] DEBUG: ui.vala:1995: Restoring window to 600x400 pixels
[+0,08s] DEBUG: autosave-manager.vala:64: Loading autosave information
[+0,08s] DEBUG: autosave-manager.vala:259: Waiting to autosave...
[+0,08s] CRITICAL: gtk_event_controller_reset: assertion 'GTK_IS_EVENT_CONTROLLER (controller)' failed
[+0,15s] DEBUG: scanner.vala:1447: sane_init () -> SANE_STATUS_GOOD
[+0,15s] DEBUG: scanner.vala:1453: SANE version 1.0.25
[+0,15s] DEBUG: scanner.vala:1514: Requesting redetection of scan devices
[+0,15s] DEBUG: scanner.vala:803: Processing request
[+0,19s] DEBUG: autosave-manager.vala:281: Autosaving book information
[+0,28s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+2,23s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+7,51s] DEBUG: scanner.vala:338: sane_get_devices () -> SANE_STATUS_GOOD
[+7,51s] DEBUG: scanner.vala:350: Device: name="smfp:usb;04e8;3441;Z5E6BFEB501435J" vendor="Samsung" model="SCX-3200 Series on USB" type="Scanner"
[+10,86s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+15,60s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+15,76s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+16,50s] DEBUG: simple-scan.vala:404: Requesting scan at 300 dpi from device 'smfp:usb;04e8;3441;Z5E6BFEB501435J'
[+16,50s] DEBUG: scanner.vala:1560: Scanner.scan ("smfp:usb;04e8;3441;Z5E6BFEB501435J", dpi=300, scan_mode=ScanMode.COLOR, depth=8, type=ScanType.SINGLE, paper_width=0, paper_height=0, brightness=0, contrast=0)
[+16,50s] DEBUG: scanner.vala:803: Processing request
[+16,53s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+16,68s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+19,40s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+50,73s] DEBUG: scanner.vala:864: sane_open ("smfp:usb;04e8;3441;Z5E6BFEB501435J") -> SANE_STATUS_IO_ERROR
[+50,73s] WARNING: scanner.vala:868: Unable to get open device: Error during device I/O
[+51,10s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+115,09s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+116,12s] DEBUG: ui.vala:2124: Saving state to /home/ja/.cache/simple-scan/state
[+117,44s] DEBUG: autosave-manager.vala:195: Deleting autosave records
[+117,44s] DEBUG: scanner.vala:1587: Stopping scan thread
[+117,44s] DEBUG: scanner.vala:803: Processing request
[+117,44s] DEBUG: scanner.vala:1598: sane_exit ()
macjan
  • 412
At the time of writing this, these 3 packages need to be downloaded and installed.
libsane-common_1.0.26~git20151121-1_all.deb
libsane_1.0.26~git20151121-1_amd64.deb
libjpeg62-turbo_1.5.1-1_amd64.deb
The first two packages can be found in the Debian experimental libs at this link https://packages.debian.org/experimental/libs/
The last package I found in this link https://packages.debian.org/sid/libjpeg62-turbo
In some cases you may need to navigate to an ftp mirror site to actually download. Once downloaded, simply install each package as root i.e sudo dpkg -i package
I have tested with simple-scan, xsane, and scangearmp and all works fine.
Thomas Ward
  • 78,878
DaveG
  • 26
install libsane-common_1.0.26~git20151121-1_all
install libsane_1.0.26~git20151121-1_amd64
install libjpeg62-turbo_1.5.1-1_amd64
Loaded repository
http://ftp.ports.debian.org/debian-ports/
synaptic only comes up with 1.0.27-1 experimental2
for sane-common. No libsane option.
Unable to find the link
Added the source url and synaptic showed
The repository may no longer be available or could not be contacted because of network problems. If available an older version of the failed index will be used. Otherwise the repository will be ignored. Check your network connection and ensure the repository address in the preferences is correct.
Had to remove repositories and re-install libsane libsane-common sane and simple-scan
user68186
  • 37,461
