I created a shell script, let's say it's
echo hi
sleep 5
echo bye
exit
Then I created a .desktop -file to launch the shell script. Double-clicking it works perfectly fine:
[Desktop Entry]
Version=1.0
Name=Test
Comment=Bash Cript
Exec=bash /example/test.sh
Terminal=true
Type=Application
Categories=Utility;Application;
After drag- and dropping the .desktop-File into the Unity Launcher, I can click on it. ONCE. After the first launch, the icon stays in the launcher, but clicking on it doesn't do anything.
Middle-Mouse clicking on it launches the application again
What am I doing wrong?
Jacob Vlijm
  • 85,475
Alex
  • 39
It does work
...even tested it, but the launcher icon is unresponsive for about 7 seconds after you clicked. If you click again after these 7 seconds, it will work again.
This "break" is caused by the icon, waiting for a window to appear. This won' t be the case, since the appearing gnome-terminal -window is "claimed" by the gnome-terminal's launcher icon, and your "home-made" icon does not recognize the window as "his".
Solution?
You could solve the issue by adding a line to your launcher (14.04)
StartupWMClass=gnome-terminal
or (16.04):
StartupWMClass=gnome-terminal-server
however, only do this for reasons of testing, don't use this as a permanent solution; having mutiple .desktop files, possibly claiming the same WM_CLASS in their main command is a bad idea, it will cause clashes in how gnome-terminal appears in the Unity launcher.
Better solution
Better add your script as a right-click option to the existing gnome-terminal launcher:
  1. Copy the global gnome-terminal launcher from /usr/share/applications to
~/.local/share/applications:
    cp /usr/share/applications/gnome-terminal.desktop ~/.local/share/applications
  1. Open the file with gedit:
    gedit ~/.local/share/applications/gnome-terminal.desktop
  2. Change the line:
    Actions=New;
    into:
    Actions=New;My Script;
    and add the section:
    [Desktop Action My Script]
    Name=My Script
    Exec=gnome-terminal -e "bash /absolute/path/to/your/script.sh"
    to the very end of the file. Then log out and back in, and you'll have your script available as a quicklist- shortcut in the gnome-terminal launcher.
Jacob Vlijm
  • 85,475
