I was struggling for a long time with installing Linux on my Macbook 2,1 from mid 2007 with no luck. Finally I've managed to install Xubuntu i386 and have tried also Ubuntu 14.10 +mac ISO. Both installations succeed, but I'm using a pretty old hardware and finally I'd like to use Xubuntu 16.10 which installation ISO is created just like newest Ubuntu ISOs (what are the changes has been described What is different about Mac ISO image?, as multi-catalog images and my old Macbook isn't able to boot them. And so I've got a question how to convert such multi-catalog ISO to "single-catalog", so old Mac can boot it?
Asked
Active
Viewed 842 times
The answer is in amd64+mac images no longer necessary. I've tried this on a iMac, late 2006, core 2 duo, and it works.
You could conceivably use mkisofs with the correctly blend of options, but this method is fool-proof.
If you are curious enough, here is a C program which i assume makes the trusty-desktop-amd64.iso bootable on your 2,1.
Put both, a copy of the ISO and the C program as make_single_eltorito.c into the same directory.
Compile the C program: cc -g -Wall -o make_single_eltorito make_single_eltorito.c
Run it without arguments (the ISO name is hardcoded in variable iso_name): ./make_single_eltorito
Put the ISO onto DVD and try booting.
Removes all entries but the first one from the El Torito boot catalog of
http://cdimage.ubuntu.com/daily-live/current/trusty-desktop-amd64.iso
Compile by:
Run without arguments in the directory where the ISO image is stored.
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
static char *iso_name = {"trusty-desktop-amd64.iso"};
int main(int argc, char **argv)
int fd, ret;
unsigned char buf[2048 - 64];
off_t lba;
size_t buf_size = 2048 - 64;
fd = open(iso_name, O_RDWR);
if (fd == -1)
goto err_ex;
if (lseek(fd, (off_t) 32768 + 2048 + 71, SEEK_SET) == -1)
goto err_ex;
ret = read(fd, buf, 4);
if (ret == -1)
goto err_ex;
if (ret < 4) {
fprintf(stderr, "Cannot read 4 bytes from %s\n", iso_name);
exit(1);
lba = buf[0] | (buf[1] << 8) | (buf[2] << 16) | (buf[3] << 24);
if (lseek(fd, lba * 2048 + 64, SEEK_SET) == -1)
goto err_ex;
memset(buf, 0, buf_size);
ret = write(fd, buf, buf_size);
if (ret == -1)
goto err_ex;
if (ret < buf_size) {
fprintf(stderr, "Cannot write %d bytes to %s\n", (int) buf_size, iso_name);
exit(1);
close(fd);
printf("done\n");
exit(0);
err_ex:;
perror(iso_name);
exit(1);
Adam
- 291
- 2
- 11
