When trying to upgrade, I get this error:
Not enough free disk space
The upgrade has aborted. The upgrade needs a total of 81.8 M free space on disk '/boot'. Please free at least an additional 81.8 M of disk space on '/boot'. Empty your trash and remove temporary packages of former installations using 'sudo apt-get clean'.
Then when I follow the instructions to free up space, I get this:
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
  linux-image-3.13.0-53-generic* linux-image-3.13.0-63-generic*
  linux-image-3.13.0-64-generic* linux-image-3.13.0-65-generic*
  linux-image-extra-3.13.0-53-generic* linux-image-extra-3.13.0-63-generic*
  linux-image-extra-3.13.0-64-generic* linux-image-extra-3.13.0-65-generic*
  linux-image-extra-3.13.0-69-generic
0 upgraded, 0 newly installed, 9 to remove and 2 not upgraded.
8 not fully installed or removed.
After this operation, 929 MB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 180855 files and directories currently installed.)
Removing linux-image-extra-3.13.0-69-generic (3.13.0-69.112) ...
depmod: FATAL: could not load /boot/System.map-3.13.0-69-generic: No such file or directory
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-69-generic /boot/vmlinuz-3.13.0-69-generic
run-parts: executing /etc/kernel/postinst.d/dkms 3.13.0-69-generic /boot/vmlinuz-3.13.0-69-generic
Error! Your kernel headers for kernel 3.13.0-69-generic cannot be found.
Please install the linux-headers-3.13.0-69-generic package,
or use the --kernelsourcedir option to tell DKMS where it's located
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-69-generic /boot/vmlinuz-3.13.0-69-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-69-generic
grep: /boot/config-3.13.0-69-generic: No such file or directory
WARNING: missing /lib/modules/3.13.0-69-generic
Device driver support needs thus be built-in linux image!
depmod: ERROR: could not open directory /lib/modules/3.13.0-69-generic: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_1pM5O4/lib/modules/3.13.0-69-generic/modules.order: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_1pM5O4/lib/modules/3.13.0-69-generic/modules.builtin: No such file or directory
gzip: stdout: No space left on device E: mkinitramfs failure cpio 141 gzip 1 update-initramfs: failed for /boot/initrd.img-3.13.0-69-generic with 1. run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1 dpkg: error processing package linux-image-extra-3.13.0-69-generic (--remove): subprocess installed post-removal script returned error exit status 1 Errors were encountered while processing: linux-image-extra-3.13.0-69-generic
I've followed many recommendation on how to fix this issue but it always returns the same error about the "no such directory"
Any help would greatly appreciated!
SoarX
Perhaps you can try and free some space first by purging out old unwanted packages using:
sudo apt-get autoremove
..and then try again with the header install using:
sudo apt-get install linux-headers-$(uname -r)
try sudo apt-get install linux-headers-$(uname -r)
from: Error! Your kernel headers for kernel 3.5.0-25-generic cannot be found
