Well you have the service running in port 5000, you want to show,proxy you service that is in 127.0.0.1:5000 or in mywebsite.com:5000 to a subdomain or domain like osrm.mywebsite.com or myosrmwebsite.com
You'll need to enable mod_proxy in Apache2 first. So run these commands as root, or sudo:
a2enmod proxy
a2enmod proxy_http
Edit your hosts file
# if you don't have access try with sudo
nano /etc/hosts
Add entry to your hosts file
# path /etc/hosts
127.0.0.1 subdomainname.mywebsite.com
87.164.25.1 subdomainname.mywebsite.com
The 87.164.25.1 is an example of ip public it isn't real
After this we need to go to /etc/apache2/sites-available
cd /etc/apache2/sites-available
Create a file *.conf for our subdomain or domain
nano subdomainname.mywebsite.com.conf
In this file we are going to create a config to proxy our port to servername
#filename 'subdomainname.mywebsite.com.conf'
#dir /etc/apache2/sites-available
<VirtualHost *:80>
ServerName osrm.website.com # my subdomain or website name server
ProxyPass / http://localhost:5000/
ProxyPassReverse / http://localhost:5000/
ProxyRequests Off
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>
note: If when you try to see the website through the url, and nothing happened, try change <VirtualHost *:80> to <VirtualHost 87.164.25.1:80> the ip that server has.
Add the *.conf file to apache with this command, and check the list of commands.
To enable it
sudo a2ensite subdomainname.mywebsite.com.conf
To disable it
sudo a2dissite subdomainname.mywebsite.com.conf
To list all sites enables
# if you want to know what sites are enables.. or check if it is enable
apache2ctl -S
To reload apache or restart
# only reload the config files without restart
sudo service apache2 reload
# restart apache
sudo service apache2 restart
Websites of reference
- How to setup subdomain on Ubuntu Server 14.04
- Get a list of all virtual hosts which are defined in all apache configuration files
- Proxy port to site - example No. 1 - https://serverfault.com/a/140161
- Proxy port to site - example No. 2 - http://freedif.org/how-to-redirect-a-port-to-a-sub-domain-proxypass/
- Proxy port to site - example No. 3 - https://stackoverflow.com/a/8442270/5287072
- Proxy port to site - example No. 4 - https://stackoverflow.com/a/589479/5287072
* I put a title and url if for some reason it fail...
