I made a little program in Java, and it run perfectly when I use the java -jar myFile.jar but when I use the "open with OpenJDK Java 7 Runtime" option, nothing happen.
I have no idea why it doesn't launch. If anybody got an idea... Thank you
You have to enable it to be executable. You can do that one time in terminal by giving it for example 755 permissions by
chmod 755 /path/javafile.jar
or
chmod +x /path/javafile.jar
Same you can do from the GUI by open the file properties, switch to the permission tab and set the check-mark as shown in the screen-shot.
