I have installed Webmin with the view to try an understand what is all running.
Yesterday I had it setup with login and password, but today when I try to get access to the server with: https://ubuntu:10000/ in order to login, I get unable to connect, the page does not load. Seems like there is no connection.
  • I tried http://localhost:10000 and https://localhost:10000 They both returned the same unable to connect response.
I am not sure of what it means to turn https on. ... the https and http is not showing.
Am I going about this the wrong way?
Jorge Castro
  • 73,717
If you did not setup webmin with https you need to to connect using http://localhost:10000 instead of https://localhost:10000.
If webmin is not starting by default on your computer you need to create a script in your /etc/init.d with this content, call the script webmin
#!/bin/sh
# chkconfig: 235 99 10
# description: Start or stop the Webmin server
### BEGIN INIT INFO
# Provides: webmin
# Required-Start: $network $syslog
# Required-Stop: $network
# Default-Start: 2 3 5
# Default-Stop: 0 1 6
# Description: Start or stop the Webmin server
### END INIT INFO
start=/etc/webmin/start
stop=/etc/webmin/stop
lockfile=/var/lock/subsys/webmin
confFile=/etc/webmin/miniserv.conf
pidFile=/var/webmin/miniserv.pid
name='Webmin'
case "$1" in
'start')
    $start >/dev/null 2>&1 </dev/null
    RETVAL=$?
    if [ "$RETVAL" = "0" ]; then
        touch $lockfile >/dev/null 2>&1
    fi
'stop')
    $stop
    RETVAL=$?
        rm -f $lockfile
    fi
    pidfile=`grep "^pidfile=" $confFile | sed -e 's/pidfile=//g'`
    if [ "$pidfile" = "" ]; then
        pidfile=$pidFile
    fi
    rm -f $pidfile
'status')
        pidfile=$pidFile
    fi
    if [ -s $pidfile ]; then
        pid=`cat $pidfile`
        kill -0 $pid >/dev/null 2>&1
        if [ "$?" = "0" ]; then
            echo "$name (pid $pid) is running"
            RETVAL=0
        else
            echo "$name is stopped"
            RETVAL=1
        fi
    else
        RETVAL=1
    fi
'restart')
    $stop ; $start
    RETVAL=$?
    echo "Usage: $0 { start | stop | restart }"
    RETVAL=1
esac
exit $RETVAL
make this executable with sudo chmod 755 /etc/init.d/webmin and add it to the startup procedure with update-rc.d webmin defaults. After this webmin will start with your computer.
To avoid all these small things you can also download webmin as a debian package that you can install in your system.
Fist you need to remove the current webmin tar install
/etc/webmin/uninstall.sh
Then install all webmin dependencies
sudo apt-get install perl libnet-ssleay-perl openssl libauthen-pam-perl libpam-runtime libio-pty-perl apt-show-versions python
Download the latest deb file from here or use this command to download the current latest version (up to this date)
wget http://dfn.dl.sourceforge.net/project/webadmin/webmin/1.570/webmin_1.570_all.deb
After downloading the file you can install it with
sudo dpkg -i webmin_1.570_all.deb
webmin will install, configure all necessary scripts and be ready for you in https://localhost:10000 all the time so you can login with your username / password.
Bruno Pereira
  • 74,715
I know this is an old thread, but nonetheless I had a similar problem and my solution was to ensure port 10000 was accepting connection. So if you are having a similar problem, you may want to try this. Connect to your server through SSH and execute the following command:
sudo iptables -A INPUT -p tcp -d 0/0 -s 0/0 --dport 10000 -j ACCEPT
For me it worked instantly. Good luck.
Edit:
Forgot to mention, you should save your iptables after adding your new rule, this can be done by running sudo service iptables save on your command line. Otherwise on server reboot, any changes done in your iptables will be lost. If that doesn't work, you can try sudo /sbin/service iptables save.
Caio Mar
  • 200
Try changing the port and listen in \etc\webmin\miniserv.conf
example:
port=1000
listen=1000
Then restart webmin:
/etc/init.d/webmin restart
Now use:
https://iporhost:1000/
Tayba
mine did this same exact thing after a reboot and i was able to access it by using the domain name of my modem/router (ex. https://myservername.routername.com:10000)
