This works for manjaro as well i had a problem with the headers but i fixed it so anyone who wants to know.
this is not a duplicate of this Cofiguring a Netgear WNDA3100 USB adapter because i installed the drivers he hast he doesnt have an internet connection and is trying to get the files whereas i already have them
So i got wine, installed my driver, went to the drivers folder, put the stuff into documents, installed ndiswrapper, and selected the driver .inf file.
It said it was a valid driver and that the hardware was present, but the USB adapter is not on and when i go to my network manager (wcid network manager), it says no network things found.
I am currently connected to the Ethernet. Any help is appreciated.
Network adapter: WNDA3100v3 Netgear adapter N600 series
Output of sudo modprobe ndiswrapper && dmesg | grep ndis
[  119.289665] ndiswrapper: module verification failed: signature and/or required key missing - tainting kernel
[  119.290674] ndiswrapper version 1.59 loaded (smp=yes, preempt=no)
[  120.426432] ndiswrapper (import:232): unknown symbol: ntoskrnl.exe:'ExEventObjectType'
[  120.426452] ndiswrapper (import:232): unknown symbol: ntoskrnl.exe:'MmGetSystemRoutineAddress'
[  120.426456] ndiswrapper (import:232): unknown symbol: ntoskrnl.exe:'IoWMIWriteEvent'
[  120.426461] ndiswrapper (import:232): unknown symbol: ntoskrnl.exe:'RtlStringFromGUID'
[  120.426483] ndiswrapper (import:232): unknown symbol: ntoskrnl.exe:'__chkstk'
[  120.426542] ndiswrapper (load_sys_files:200): couldn't prepare driver 'rt2870'
[  120.427014] ndiswrapper (load_wrap_driver:103): couldn't load driver rt2870; check system log for messages from 'loadndisdriver'
[  120.427071] usbcore: registered new interface driver ndiswrapper
Output of lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 004 Device 002: ID 0bc2:ab26 Seagate RSS LLC
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 005: ID 0846:9014 NetGear, Inc.
Bus 003 Device 003: ID 03f0:134a Hewlett-Packard Optical Mouse
Bus 003 Device 002: ID 03f0:034a Hewlett-Packard Elite Keyboard
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Your 0846:9014 device is supposed to work with the native driver mt7662u_sta. First, remove ndiswrapper:
sudo apt-get purge ndiswrapper-common
sudo apt-get purge ndiswrapper-utils-1.9
Now we'll build the new driver. With a temporary working internet connection and with the device unplugged:
sudo apt-get update
sudo apt-get install git
git clone https://github.com/jurobystricky/Netgear-A6210
cd Netgear-A6210
make
sudo make install
Plug in the device and let us have your report.
You have built the driver for your current kernel version only. When Update Manager installs a later kernel version, known as linux-image, recompile:
cd Netgear-A6210
make clean
make
sudo make install
Reboot.
Please retain the file and these instructions for that time.
chili555
  • 61,330
When you install something with ndiswrapper, make sure to use modprobe to activate it. first try sudo modprobe ndiswrapper and if that does not work, try to reinstall ndiswrapper, and then once you do that, reinstall the .ini file. also, usually, windows drivers install a 32-bit version, and a 64 bit version. make sure you are using the correct version.
PMiner
  • 17
Have you tried the basic troubleshooting steps here:
First, check if any devices are hard blocked with RF kill:
rfkill list all
Make sure the adapter is recognized:
sudo lshw
Bring up the adapter:
sudo ifconfig wlan0 up
sudo iwconfig wlan0 essid (network_name) key (network_key)
*of course replacing network_name and network_key...
Finally...
sudo dhclient wlan0
to get an IP and connect to your chosen network...
Have you tried those yet?
P Smith
  • 569
