I can get a list of all available packages and their details using the following command:
apt-cache search .
Which outputs a list of packages which looks like this:
i   0ad                - Real-time strategy game of ancient warfare
i   0ad-data           - Real-time strategy game of ancient warfare (data files)
i   0ad-data-common    - Real-time strategy game of ancient warfare (common data files)
p   0ad-dbg            - Real-time strategy game of ancient warfare (debug)
p   0xffff             - Open Free Fiasco Firmware Flasher
p   2ping              - Ping utility to determine directional packet loss
p   2vcard             - perl script to convert an addressbook to VCARD file format
p   3270-common        - Common files for IBM 3270 emulators and pr3287
p   389-admin          - 389 Directory Administration Server
How can I get such a list of packages for a version of Ubuntu which I don't have installed?
So, specifically, where can I download the database of all available packages for a specific version of Ubuntu, and how do I get the details (Possibly including version, size, long description...) from it, in plaintext or in a format which is easy to parse with a script?
muru
  • 207,228
Jonas Czech
  • 4,047
5 Answers5
11
1. On-line
I prefer use of http://packages.ubuntu.com/ as muru's answer.
  • Pro: It has always updated list, but includes only official repository.
  • Con: It is a nightmare to follow PPA's and external repositories one by one.
2. For Off-line use, Manual
Otherwise looking for an off-line solution then you should be MR. APT and start downloading them from http://archive.ubuntu.com/ubuntu/dists/.
p=$(pwd); for c in main universe multiverse restricted; do for u in "" -security -updates; do for a in binary-amd64 binary-i386; do mkdir trusty${u}_${c}_$a; cd trusty${u}_${c}_$a; wget http://archive.ubuntu.com/ubuntu/dists/trusty$u/$c/$a/Packages.bz2; cd $p; done; done; done;
Results:
$ tree
├── trusty_main_binary-amd64
│   └── Packages.bz2
├── trusty_main_binary-i386
│   └── Packages.bz2
├── trusty_multiverse_binary-amd64
│   └── Packages.bz2
├── trusty_multiverse_binary-i386
│   └── Packages.bz2
├── trusty_restricted_binary-amd64
│   └── Packages.bz2
├── trusty_restricted_binary-i386
3. For Off-line use, using apt-cache/overlay-filesystem/chroot
Going bad, advanced setup:
  • OverlayFS: Create a lightweight partial copy of current FS tree, with modification. Objective is change only release name in source.lists . How does OverlayFS work is explained here in this post or from ArchLinux Wiki. Alternative way would be: fuse-overlayfs
  • chroot: Get shell command in that modified file tree. Alternative way: overlayroot-chroot
  • apt-cache: Search for packages
I'm going to use a custom sources.list* with same apt-cache installed on 16.04, but apt will not overwrite the 16.04 real lists files in /var/lib/apt/lists/, All changes (mine or generated ones) will go to the overlay file-system.
Setup:
sudo apt-get install chroot
mkdir sandbox0
cd sandbox0
mkdir upper work merged
sudo mount -t overlay overlay -o lowerdir=/,upperdir=./upper,workdir=./work ./merged
sudo chroot merged/
echo "deb http://archive.ubuntu.com/ubuntu/ trusty universe multiverse main restricted" > /etc/apt/sources.list
rm -r /etc/apt/sources.list.d/*
apt-get update
exit
Use: (you may prepare a script)
sudo chroot merged/
apt-cache ...
user.dz
  • 49,176
Use chdist. This command allows you to run apt-get and apt-cache as usual, but for a different release of Ubuntu (or Debian or in fact any other Debian-derived distribution).
It also provides a wrapper around grep-dctrl which easily allows you to search and report on metadata fields.
Robie Basak
  • 15,910
You can install html2text and try searching in xenial (for example) for ocaml packages :
curl -k -s https://packages.ubuntu.com/xenial/allpackages | html2text | egrep '^ +ocaml'
SebMa
  • 2,927
  • 35
  • 47
You already have the command to list all possible posted, but ok lets go a bit deeper shall we? So apt-cache search . or apt-cache search '' output around 2300+ lines which is in fact the whole amount of all possible packages including different DE versions.
To make it more easy you could only get the names with:
apt-cache search '' | sort -d | awk '{print $1}'
Or is you like more information and dont mind a long long list you could roll that through apt-cache policy:
apt-cache policy $(apt-cache search '' | sort -d | awk '{print $1}')
Videonauth
  • 33,815
Just to complete @Robie-Basak 's answer, here an example with the chdist tool querying Ubuntu Trusty (14.04) sources :
$ chdist create 14.04
Now edit /home/myName/.chdist/14.04/etc/apt/sources.list
Run chdist apt-get 14.04 update
And enjoy.
$ chdist list
14.04
$ cat /etc/apt/sources.list | sed s/$(lsb_release -sc)/trusty/ | tee ~/.chdist/14.04/etc/apt/sources.list >/dev/null
$ chdist apt-get 14.04 update
Ign:1 http://fr.archive.ubuntu.com/ubuntu trusty InRelease
Hit:2 http://fr.archive.ubuntu.com/ubuntu trusty-updates InRelease
Hit:3 http://fr.archive.ubuntu.com/ubuntu trusty-backports InRelease
Hit:4 http://fr.archive.ubuntu.com/ubuntu trusty-security InRelease
Hit:5 http://fr.archive.ubuntu.com/ubuntu trusty Release
Reading package lists... Done
$ chdist apt-cache 14.04 policy ocaml-nox
ocaml-nox:
  Installed: (none)
  Candidate: 4.01.0-3ubuntu3.1
  Version table:
     4.01.0-3ubuntu3.1 500
        500 http://fr.archive.ubuntu.com/ubuntu trusty-updates/main amd64 Packages
        500 http://fr.archive.ubuntu.com/ubuntu trusty-security/main amd64 Packages
     4.01.0-3ubuntu3 500
        500 http://fr.archive.ubuntu.com/ubuntu trusty/main amd64 Packages
And if you are behind a proxy defined in the /etc/apt/apt.conf.d/00aptproxy file (for example), than you must type this command BEFORE typing your chdist apt-get 14.04 update :
$ cp -puv /etc/apt/apt.conf.d/00aptproxy ~/.chdist/14.04/etc/apt/apt.conf.d/00aptproxy
'/etc/apt/apt.conf.d/00aptproxy' -> '/home/myName/.chdist/14.04/etc/apt/apt.conf.d/00aptproxy'
SebMa
  • 2,927
  • 35
  • 47
