Hi I'm installing stockfish to be used on scid. I followed these two tutorials, using stockfish from the stockfish website rather than from git.
https://www.chess.com/article/view/scid--stockfish
http://support.stockfishchess.org/kb/advanced-topics/compiling-stockfish-on-linux
I installed scid by:
sudo apt-get install scid
I downloaded engine binaries for stockfish7 for Linux from
https://stockfishchess.org/download/
I read that you need to compile it first so i compiled the stockfish engine with sudo apt-get install git g++. Tested it with make profile-build ARCH=x86-32 then I went to add the engine in scid, with settings:
command: stockfish
directory: /home/user/Desktop/stockfish-7-linux/Linux/src/.stockfish
UCI on
but then It tells me that unable to start the program: stockfish.
that error is the default response for any error. If I typed in folders that don't exist and a file that doesn't exist, it gives that error too. What am I doing wrong?
terdon
  • 104,119
Qwertford
  • 283
First of all you need the absolute path to command , in my case:
/usr/local/bin/stockfish
Directory i just pressed button at the right that point to scid in your home directory :
~/.scid
Notice that if you have done steps on stockfish page the final step is :
./stockfish
But to use it as i did do one more step :
sudo make install
This give the output directory .
E_Angel
  • 391
