I have got problem in Ubuntu 16.04.
My system has 2 drives with RAID 1. I tried all that I found but didn't work. I matched the /etc/fstab and /boot/grub/menu.lst file with both /dev/md126 also with UUID-.... but it didn't work.
My system shows this error message on boot:
(cat /proc/modules; ls /dev)
ALERT ! UUID-853f6ofa-be83-4b2c-b111-89f7fb09d20ff does not exist. Dropping to a shell
Below is the out for blkid
/dev/sdc1: UUID="2016-04-20-22-45-29-00" LABEL="Ubuntu-Server 16.04 LTS amd64" TYPE="iso9660" PTUUID="4cbe268b" PTTYPE="dos" PARTUUID="4cbe268b-01"
/dev/sdc2: SEC_TYPE="msdos" UUID="B1F5-0A13" TYPE="vfat" PARTUUID="4cbe268b-02"
/dev/sdb1: UUID="b1e8f589-8e85-4396-f038-bda09701b1e4" UUID_SUB="70870fef-1666-c0e2-e80d-719c290f2b10" LABEL="Odoo:0" TYPE="linux_raid_member" PARTUUID="2c3f2dea-01"
/dev/sdb2: UUID="8cd06e11-af74-a75b-e1f6-228eed6e6e50" UUID_SUB="c9afe7eb-e625-be77-64c1-f13e79fb0eb0" LABEL="odoo:128" TYPE="linux_raid_member" PARTUUID="2c3f2dea-02"
/dev/sda1: UUID="b1e8f589-8e85-4396-f038-bda09701b1e4" UUID_SUB="eb4b677b-7d08-eaed-bcee-afe4853de434" LABEL="Odoo:0" TYPE="linux_raid_member" PARTUUID="ed1431b2-01"
/dev/sda2: UUID="8cd06e11-af74-a75b-e1f6-228eed6e6e50" UUID_SUB="8ca1a95f-7651-b741-7c03-8d217b1be0f9" LABEL="odoo:128" TYPE="linux_raid_member" PARTUUID="ed1431b2-02"
/dev/md127: UUID="853f60fa-be83-4b2c-b111-89f7b09d20ff" TYPE="ext4"
/dev/md126: UUID="ce1bb201-a6ee-402b-9aa3-e782560575d9" TYPE="swap"
/dev/sdd1: LABEL="GRMCULFRER_" UUID="4823-0029" TYPE="vfat" PARTUUID="fdc01076-01"
/etc/fstab contents:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/md128 during installation
UUID=853f60fa-be83-4b2c-b111-89f7b09d20ff / ext4 errors=remount-ro 0 1
# swap was on /dev/md127 during installation
UUID=ce1bb201-a6ee-402b-9aa3-e782560575d9 none swap sw 0 0
How can I solve this problem?
