Steps to replicate:
Ubuntu 16.04 xenial (x86-64)
sudo apt-get update
sudo apt-get install nodejs
sudo apt-get install npm
I want to uninstall nodejs and npm and have seen several posts which suggest this is the most common way:
sudo apt-get purge --auto-remove nodejs
However, this produces a prompt which seems to reference dependencies which, if they were removed, sound like they would cause problems.
What is the best way to "undo" the install of nodejs and npm?
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
gyp* libboost-python1.58.0* libjs-inherits* libjs-node-uuid*
libjs-underscore* libssl-dev* libssl-doc* libuv1* libuv1-dev*
linux-headers-4.4.0-18* linux-headers-4.4.0-18-generic*
linux-headers-4.4.0-21* linux-headers-4.4.0-21-generic*
linux-image-4.4.0-18-generic* linux-image-4.4.0-21-generic*
linux-image-extra-4.4.0-18-generic* linux-image-extra-4.4.0-21-generic*
linux-signed-image-4.4.0-18-generic* linux-signed-image-4.4.0-21-generic*
node-abbrev* node-ansi* node-ansi-color-table* node-archy* node-async*
node-block-stream* node-combined-stream* node-cookie-jar*
node-delayed-stream* node-forever-agent* node-form-data* node-fstream*
node-fstream-ignore* node-github-url-from-git* node-glob* node-graceful-fs*
node-gyp* node-inherits* node-ini* node-json-stringify-safe* node-lockfile*
node-lru-cache* node-mime* node-minimatch* node-mkdirp* node-mute-stream*
node-node-uuid* node-nopt* node-normalize-package-data* node-npmlog*
node-once* node-osenv* node-qs* node-read* node-read-package-json*
node-request* node-retry* node-rimraf* node-semver* node-sha* node-sigmund*
node-slide* node-tar* node-tunnel-agent* node-underscore* node-which*
nodejs* nodejs-dev* npm* python-configobj* python-pycurl* python-pyexiv2*
python-pyexiv2-doc*
0 to upgrade, 0 to newly install, 72 to remove and 0 not to upgrade.
After this operation, 631 MB disk space will be freed.
Do you want to continue? [Y/n]
Edit:
This is the output from sudo apt-get purge nodejs:
The following packages were automatically installed and are no longer required:
gyp libboost-python1.58.0 libjs-inherits libjs-node-uuid libjs-underscore
libssl-dev libssl-doc libuv1 libuv1-dev linux-headers-4.4.0-18
linux-headers-4.4.0-18-generic linux-headers-4.4.0-21
linux-headers-4.4.0-21-generic linux-image-4.4.0-18-generic
linux-image-4.4.0-21-generic linux-image-extra-4.4.0-18-generic
linux-image-extra-4.4.0-21-generic linux-signed-image-4.4.0-18-generic
linux-signed-image-4.4.0-21-generic python-configobj python-pycurl
python-pyexiv2 python-pyexiv2-doc
Use 'sudo apt autoremove' to remove them.
0 to upgrade, 0 to newly install, 49 to remove and 0 not to upgrade.
After this operation, 27.6 MB disk space will be freed.
