If I run ./deviceQuery without sudo:
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 30
-> unknown error
Result = FAIL
But running it with sudo (sudo ./deviceQuery) works, and after I run it once with sudo, subsequent runs of ./deviceQuery without sudo also results in pass.
My guess is that the first run with sudo initialises some files correctly which would otherwise cause it to fail. I am not sure how to debug this further, however.
When I build i had to do:
sudo make -j4
Otherwise some errors pop out, then I had same problem.
Change permissions from inside samples folder:
sudo chmod 755 -Rf *
sudo chown nobody:nogroup -Rf
Hope its not to layman way tho :D
