Ever since I update to 16.04 I notice whenever I use any sudo command the terminal does not ask me the password before executing the command,The command is directly executed.I am the admin and I have no other user accounts.
I have seen sudo does not ask for password and my /etc/sudoers is exactly like given in answer but still when using sudo command, terminal does not prompt a password instead execute the command.
I would like to know in detail how can /etc/sudoers can be modified for
  • Making any particular user account(including admin) to be prompted or not prompted for password when using sudo command.
  • How to exclude any particular command to be excluded from prompting password when using sudo for any user account(including admin).
Here is my sudoers file
# /etc/sudoers
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults    env_reset,timestamp_timeout=0
# Uncomment to allow members of group sudo to not need a password
# %sudo ALL=NOPASSWD: ALL
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification root ALL=(ALL) ALL
# Members of the admin group may gain root privileges %admin ALL=(ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
Output of sudo -l
Matching Defaults entries for bharat on ratcoder:
    env_reset, timestamp_timeout=0
User bharat may run the following commands on ratcoder:
    (ALL) NOPASSWD: ALL
bha159
  • 611
You had a NOPASSWD rule applied to your user in some file in /etc/sudoers.d. Use sudo grep NOPASSWD /etc/sudoers.d -R to find out which.
Your /etc/sudoers is not the default, however. The default sudoers can be obtained by looking at the sudo package:
$ apt-get download sudo
Get:1 http://mirror.cse.iitk.ac.in/ubuntu xenial-updates/main amd64 sudo amd64 1.8.16-0ubuntu1.1 [389 kB]
Fetched 389 kB in 0s (4,750 kB/s)
$ dpkg-deb --fsys-tarfile sudo*.deb | tar x ./etc/sudoers
$ cat etc/sudoers
Defaults    env_reset
Defaults    mail_badpass
Defaults    secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
root    ALL=(ALL:ALL) ALL
# Allow members of group sudo to execute any command
%sudo   ALL=(ALL:ALL) ALL
This is rather different from what you have. Restore /etc/sudoers to the default.
For excluding specific commands from requiring a password, see How do I run specific sudo commands without a password?
muru
  • 207,228
Edit your sudoers file using sudo visudo.
Find this line: Defaults env_reset and change it to this:
This forces sudo to ask for a password every time your run it.
Stormlord
  • 6,807
The OP doesn't mention which user is the admin user. Likely it is a created user account (and so this may not apply), but for other people who come across this thread I mention this: when using the current Ubuntu 16.04 AMI on AWS, the ubuntu user by default does not require a password for sudo so that cloud-init can use it to execute. This access is defined in /etc/sudoers.d/90-cloud-init-users, like so:
# User rules for ubuntu
ubuntu ALL=(ALL) NOPASSWD:ALL
Ville
  • 141
