I cant login to the Ubuntu 14.04 but I can access the guest user.
If I enter the correct password, it flashes and comes back to the same login screen and if I enter wrong password it mentions invalid password (so I'm not entering the wrong password)
I used disks to auto mount one ntfs partition using this guide before the issue started and I used mount point as /home. So I wonder if thats the issue.
Can boot in to the recovery but login using ctrl+alt+F1 didn't work , it says incorrect login. I am dual booting Windows 7 and Ubuntu 14.04 and can access windows.
(I did go through other threads with same issues but none of them worked)
balus
Selected recovery from grub menu. Selected root shell.
Remounted it in write mode
mount -w -o remount /
Edited fstab
nano /etc/fstab
Saved it and restated and it is working fine now.
balus
Login as a guest user. Then look at the contents of /etc/fstab and delete the line with the mountpoint '/home' in it. You can do this by opening a terminal enter the command:
sudo nano /etc/fstab
Save the file. Then reboot and see if you can login. I don't know what you already tried to fix it but this could work. At the moment I can't test if you can edit fstab as a guest user so I'm not sure if it works.
You could also try the solutions in this post: Ubuntu gets stuck in a login loop The following command fixed it for me when my machine got stuck in a login loop.
dpkg-reconfigure lightdm
