The other answer is great! But it requires root cron.
If you want to hibernate from non-sudo cron, there are 2 options:
Make a file containing the following:
[Enable hibernate to be run via cron]
Identity=unix-user:*
Action=org.freedesktop.login1.hibernate;org.freedesktop.login1.hibernate-multiple-sessions
ResultAny=yes
named com.0.enable-hibernation-from-cron.pkla in the directory /etc/polkit-1/localauthority/50-local.d/.
Explanation is given here.
Quoting from here:
If users should only be allowed to use shutdown commands, but not have
  other sudo privileges, then, as root, add the following to the end of
  /etc/sudoers using the visudo command.
user hostname =NOPASSWD: /usr/bin/systemctl poweroff,/usr/bin/systemctl halt,/usr/bin/systemctl reboot
Substitute user for your username and hostname for the machine's hostname.
  Now your user can shutdown with sudo systemctl poweroff, and reboot
  with sudo systemctl reboot. Users wishing to power down a system can
  also use sudo systemctl halt.
  Use the NOPASSWD: tag only if you do not want to be prompted for your password.
In my case, the exact line is:
anmol ALL=NOPASSWD: /bin/systemctl hibernate
(Note that the location of systemctl might be different on your system.)
After this, you can write sudo systemctl hibernate fron cron to hibernate.
Note: Directly modifying /etc/sudoers is bad; instead make a custom sudoers file under /etc/sudoers.d/ using the command - sudo visudo -f /etc/sudoers.d/custom.
