I'm on Ubuntu 16.04, tring to use Virtualbox version 5.0_5.0.20
When I try to open a Virtual Machine, Virtualbox warn me that :
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (4.4.0-22-generic) or it failed to
load. Please recompile the kernel module and install it by
sudo /sbin/rcvboxdrv setup
You will not be able to start VMs until this problem is fixed.
So I run the command sudo /sbin/rcvboxdrv setup as asked, but I meet the error
Stopping VirtualBox kernel modules ...done.
Uninstalling old VirtualBox DKMS kernel modules ...done.
Trying to register the VirtualBox kernel modules using DKMS ...done.
Starting VirtualBox kernel modules ...failed!
(modprobe vboxdrv failed. Please use 'dmesg' to find out why)
And I'm blocked ... I don't know how to fix it to run my VM.. Any Idea ?
