Whenever I try to install some software or plugin or codec, i'm often getting this problem :
Ignoring file 'mono-xamarin.lit' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
Please help me with a solution.
The solution is easy for you to achieve, rename the file in question to be a proper file or remove it. To rename it you can do the following command:
sudo mv /etc/apt/sources.list.d/mono-xamarin.lit /etc/apt/sources.list.d/mono-xamarin.list
Or for removing it
sudo rm /etc/apt/sources.list.d/mono-xamarin.lit
Videonauth
  • 33,815
