I was updating my laptop's software, the laptop hanged up so I shutted it down and restarted it after a while to find out that all the files were suddenly deleted, how can I recover the lost items?!
Asked
Active
Viewed 66 times
Try scalpel. This is the manpage.
Or try GNU Parted.
Run:
sudo swapoff -a
sudo parted /dev/sdx
Then run (in parted):
rescue START END
START and END are where the partition starts and ends.
Disclaimer: Please do not downvote my answer if it doesn't work as data recovery is one of the most various answerable questions and every method may or may not work.
fosslinux
- 3,881
When upgrading form one version of Ubuntu to another, some files and packages may be deleted in the process, as being considered no longer necessary after the update. That shouldn't happen to personal files though.
If you didn't secure erase those files, delete partitions or delete/replace the partition table, your files should still be recoverable. You can use LiveCD/USB with rescue tools, like Trinity Rescue Kit, Ultimate BootCD, Parted Magic.
ipse lute
- 2,614
