I need to connect Ubuntu 14.04 (64) server to Windows VPN.
I've installed sstp client sstp-client (1.0.10) with lib, setup /etc/ppp/chap-secrets and a /etc/ppp/peers/mypeer
Seems, on sudo pon mypeer the server connects to VPN.
$ sudo plog
Jun  8 04:20:08 sg2 pppd[61835]: local  IP address 10.10.99.24
Jun  8 04:20:08 sg2 pppd[61835]: remote IP address 10.10.99.1
Jun  8 04:20:08 sg2 pppd[61835]: primary   DNS address 10.10.10.9
Jun  8 04:20:08 sg2 pppd[61835]: secondary DNS address 10.10.10.10
Jun  8 04:20:08 sg2 pppd[61835]: Script /etc/ppp/ip-up started (pid 62219)
Jun  8 04:20:08 sg2 pppd[61835]: Script /etc/ppp/ip-up finished (pid 62219), status = 0x0
Jun  8 04:20:10 sg2 pppd[61835]: sent [CCP ConfReq id=0xb]
Jun  8 04:20:10 sg2 pppd[61835]: rcvd [CCP TermAck id=0xb]
Jun  8 04:20:10 sg2 pppd[61835]: sent [CCP TermReq id=0xc"No compression negotiated"]
Jun  8 04:20:10 sg2 pppd[61835]: rcvd [CCP TermAck id=0xc"No compression negotiated"]
routes before connecting:
$ route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.0.3     0.0.0.0         UG    0      0        0 eth0
172.17.0.0      0.0.0.0         255.255.0.0     U     0      0        0 docker0
192.168.0.0     0.0.0.0         255.255.252.0   U     0      0        0 eth0
and routes after connection:
$ route -n
10.10.99.1      0.0.0.0         255.255.255.255 UH    0      0        0 ppp0
The difference is:
As I understand, that defines the route to the host 10.10.99.1 over ppp0 interface
Issues I can't resolve
1. I can't ping that host, despite I can ping it from Windows workstation connected to the same VPN. How to make it work?
2. Also if I manually define a new route:
$ sudo route add -net 10.10.0.0 netmask 255.255.0.0 gw 10.10.99.1
I see the new route:
10.10.0.0       10.10.99.1      255.255.0.0     UG    0      0        0 ppp0
But I still cannot access any host in VPN. What is wrong with my route?
UPDATE - ping
$ ping -c 3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=59 time=2.92 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=59 time=2.60 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=59 time=2.99 ms
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 2.603/2.839/2.994/0.169 ms
$ ping -c 3 -I ppp0 8.8.8.8
PING 8.8.8.8 (8.8.8.8) from 10.10.99.2 ppp0: 56(84) bytes of data.
3 packets transmitted, 0 received, 100% packet loss, time 1999ms
UPDATE - version
Tried also sstp client (1.0.9) with no luck
zuba
  • 2,423
Add this route using the command line or the VPN Connection Settings:
route add -net 10.10.99.24 netmask 255.255.255.255 metric 1 gw 192.168.0.3
Ehsan
