How do I disable Spotify notifications? Remove spotify pop-up notification when a song starts doesn't work, as there's nothing called "notification" in the ~/.config/spotify/Users/[Spotify user name]-user/prefs file
Ywen
  • 191
As @edwinksl said in a comment you can actually do this right from the GUI.
  1. Hit the down arrow in the top right corner
  2. Select the settings option
  3. Last option under 'Display Options' should read 'Show desktop notification....' tap/click that and they'll be disabled.
gcalex5
  • 131
Ok, simply adding ui.track_notifications_enabled=false as the first line of the file works. It's apparently normal if the field doesn't exist
Ywen
  • 191
Quit Spotify and add ui.track_notifications_enabled=false in a new line anywhere in this file:
~/.config/spotify/Users/[spotify-user-name]-user/prefs
or ~/snap/spotify/current/.config/spotify/Users/[spotify-user-name]-user/prefs
and save.
  • If nothing has changed, make sure you have quit Spotify and try editing the file again.
  • If the prefs file doesn't exist create it and add mentioned line.
Also, you can change it in Spotify itself:
Settings > Display Options and toggle off: Show desktop notifications when the song changes
Zanna
  • 72,312
maciejwww
  • 201
