My Dell Optiplex 780 is blanccoed, how do I know whether I need a 32 or 64 bit ubuntu?
muru
  • 207,228
Igneri
  • 39
What your CPU supports
Your CPU is 64-bit, as are virtually all desktop CPUs made in the last 11 years.
  • The first AMD CPUs to support 64-bit were the Opteron and the Athlon 64 in 2003.
  • The first Intel CPUs to support the current 64-bit instructions were the Pentium 4F and the Pentium D in 2005, and the first Intel Core CPU to support it was the Core 2 in 2006.
Most desktop and notebook CPUs made since this have supported 64-bit, with some exceptions in the early days.
You can still install a 32-bit operating system and 32-bit software on a 64-bit processor, but it comes with limitations: you won't be able to utilise 4GB or more of RAM (with some exceptions), a single process won't be able to use more than 2GB (usually) of RAM, and you won't be able to utilise many of the new instructions in AMD64/Intel 64 which can potentially speed up programs.
Is there any reason to install a 32-bit OS?
There have historically been some drawbacks to using 64-bit, but these are all but irrelevant now:
  • Software compiled for 64-bit is usually a little larger due to using 64-bit pointers instead of 32-bit, but that is offset by the ability to use large amounts of RAM - 8GB is cheap and plenty these days and of course can only be fully utilised by 64-bit software.
  • 64-bit operating systems require driver code to be 64-bit. At one point in time, manufacturer support for 64-bit drivers was poorer than 32-bit, but this situation is probably the reverse now.
thomasrutter
  • 37,804
Here's some information about arhitectures that you might find useful. There's a link provided at the bottom that leads to a full article.
Which is Better - 32 or 64 Bits?
If you are doing heavy work where you have started to hit the 4GB memory barrier, then 64-bit is for you. Certain intensive tasks such as encoding video or audio also run significantly faster on 64-bit operating systems (NOTE: this is implementation specific).
Phoronix has done some testing (2009), comparing 32bit/PAE/64bit, and this seems to indicate that 64bit performs better than 32bit in almost all cases.
Early 64-bit adopters were plagued by incompatibility problems (most noticeably Java and Flash), however most issues have now been resolved.
Some applications such as Flash do run slower in 64-bit mode, however work continues to improve on this.
Other platforms which also come in 32 and 64-bit flavours may experience more problems especially due to a lack of 64-bit device drivers as incompatible user application. As Ubuntu is entirely open source, this is not the case as all hardware supported by Ubuntu works equally well in 32-bit and 64-bit environments. The same applies to open source user applications as well.
Which Should I Choose?
Unless you have specific reasons to choose 32-bit, we recommend 64-bit to utilise the full capacity of your hardware.
Source
JoKeR
  • 7,062
A quick search online would've showed you that it's a 64 system.
The Decision
It depends on you and the central processing unit.
How do you know if you have a 64 bit architecture?
Search online for the make / model / brand of your PC and find the processor specs. If nothing is telling you "64-bit" do an online search for the processor name.
If you have a 64 bit processor, get the 64-bit version
Here is why:
The 64-bit version is easier to obtain. (Convenient)
It is likely a 32-bit application is 64-bit compatible. (Practical)
Applications like Google Chrome are not 32 bit compatible (Usable)
If you've got a 32-bit processor, get the 32 bit version
You don't have a choice. You might want to start thinking about getting an upgrade.
