I'm new so go easy as I know it may be a simple answer to most, however I came from Linux Mint and I know that the software center's are very similar. I feel that mint is easier to use, however I know for gaming that ubuntu down right destroys the competition for linux distro's in fraps. This is my reason for changing. Also, for whatever reason(knock on wood) Ubuntu seems to run smoother than the Mint did(no idea why. I'm using the same partition as I did for Mint)
What I want to know is why "Playonlinux" as well as "Wine" is missing from the Ubuntu software center after a fresh install. Please, be specific when answering as I may follow up with another question if the answer is vague. Thank you for your help.
I had the same problem so I tried to reinstall the ubuntu software center. I don't know why but it works.
First of all, unlock it from launcher, click the right button on it and you see that option. Then open the terminal and type
sudo apt-get update && sudo apt-get upgrade
after that
sudo apt-get install software-center
If you use ubuntu 16.04 you could just type apt instead of apt-get. And finally go to /usr/share/applications, find the new ubuntu software center and move it to the launcher.
On my 14.04 wine and playonlinux are respectively in the "universe" and "multiverse" repositories. Check that you have these enabled in your software sources.
xenoid
  • 5,759
It seems the new Ubuntu Software app isn't quite ideal. I can find neither Play on Linux nor Wine Windows Program Loader with it. However, If I install Ubuntu Software Center with sudo apt-get install software-center and run Ubuntu Software Center instead of Ubuntu Software, both show up if I search wine.
Elder Geek
  • 36,752
