My PC always reboots 5 seconds after its turned off. I looked at Reboot after shutdown (Ubuntu 14.04 (also 12.04); Dell latitude E7440), but:
the top rated answer didn't help since I have no power options in the F2 menu. I changed wake on lan to disable, didn’t help.
The 2nd answer had 3 steps. I did step 1 and 3. Didn’t help. When I enter the command for step 2 the terminal is empty.
If it helps, I have an acer v5-571.
cat /proc/acpi/wakeup:
Device S-state Status Sysfs node
P0P1 S4 *disabled
GLAN S4 *disabled
EHC1 S3 *enabled pci:0000:00:1d.0
EHC2 S3 *enabled pci:0000:00:1a.0
XHC S3 *enabled pci:0000:00:14.0
HDEF S3 *disabled pci:0000:00:1b.0
RP01 S4 *disabled pci:0000:00:1c.0
PXSX S4 *disabled
RP02 S4 *disabled
PXSX S4 *disabled
RP03 S5 *disabled pci:0000:00:1c.2
PXSX S5 *disabled pci:0000:02:00.0
*disabled platform:rtsx_pci_sdmmc.0
*disabled platform:rtsx_pci_ms.0
RP04 S4 *disabled pci:0000:00:1c.3
PXSX S4 *disabled pci:0000:03:00.0
RP05 S4 *disabled
PXSX S4 *disabled
RP06 S4 *disabled
PXSX S4 *disabled
RP07 S4 *disabled
PXSX S4 *disabled
RP08 S4 *disabled
PXSX S4 *disabled
PEG0 S4 *disabled
PEGP S4 *disabled
PEG1 S4 *disabled
PEGP S4 *disabled
PEG2 S4 *disabled
PEG3 S4 *disabled
LID0 S3 *enabled platform:PNP0C0D:00
SLPB S3 *enabled platform:PNP0C0E:00
So, in the other thread you posted to me, he had XHC EHC1 EHC2 as the sources of the reboot, so I tried to take the shortcut and disable them as well, but again (maybe because I lack a word like with the last command), my access is denied.
I entered his solution:
for device in XHC EHC1 EHC2; do
if grep -Fe "$device" /proc/acpi/wakeup | grep -qFe enabled; then
echo "Disabling wakeup on $device"
echo "$device" > /proc/acpi/wakeup
fi
done
Unfortunately the format isn’t kept, so it is a bit of a mess, hope you still see through.
