I installed Ubuntu 16.04, encrypted home directory. Jotted down system info including password, etc., in a document which will presumably be in /home/mike/somewhere. Hadn't printed the file to hardcopy yet. Installed steam, which when executed hard-crashed the machine, no jumpout to F1, no ssh'ing in from local machine, nothing. Rebooted, and realized I cannot remember my robust password nor had I printed out my file.
How do I reset the password is the question?
Before you answer, here's what I've tried and does NOT work in Ubuntu 16.04 under these circumstances:
- Booting in to recovery mode, dropping to command line gives "Give root password for maintenance"
- Booting and pausing at grub stage, editing the boot line by changing
rotorwand addinit=/bin/bash, (also deleting the splash text, i can't remember the exact words), hitting F10 to boot with new options, results in blank screen, then the regular GNOME GUI log-in. Tried a few variations on this. - Booting from live USB stick, dropping into terminal with F1, I can log in, and
sudo. Hope is born! I mounted/dev/sdb2(my Linux installation) to/mnt,sudo chroot /mnt. I change to/mnt. I successfully changemike's password. Reboot: rejects the new password.
I had made a second user on the machine to run a process, and that home directory is not encrypted. I did the live USB stick boot, dropped into terminal, changed password on the second user, and promoted him to a sudo-er as well. Rebooted normally, logged in as him, am able to change password for mike, sudo into mike: all variations on this theme result in asking for passphrase to unencrypt the home directory.
Is this hopeless or is there a back door I don't know about?
