I have sandisk 8GB
I had kali linux installed. I tried to create Bootable live Ubuntu pendrive. I went to the terminal and issued the following commands:
sudo dd if=/dev/zero of=/dev/sdb bs=1k count=2048
sudo parted /dev/sdb mklabel msdos
sudo parted -a none /dev/sdb mkpart  primary fat32 0 2048
mkfs.vfat -n "Disk" /dev/sdb1
sudo dd if=./ubuntu.iso of=/dev/sdd bs=8129
It created bootable live USB installer for Ubuntu successfully.
After dual booting my latop with Ubuntu and Kali linux I now need the pendrive for data storing purpose
It was showing a capacity of only 64 MB. I used dd command to reformat it but that wouldn't help. I also used gparted but that didn't help.
What to do now?
rancho
  • 4,136
You can try to select "Create partition table", under the device menu in Gparted, in order to fully reformat it. (Select msdos as the partition table type). Then, you should be able to create a new partition on the USB stick.
If that doesn't work, a very simple (But slow, and I'm sure there's a better way) way to fix this would be to simply overwrite the entire drive with dd, by using something like this:
sudo dd if=/dev/zero of=/dev/sdb bs=4M
Which will overwrite the entire contents with zeroes, after which you should be able to create a partition table and a partition with Gparted as described above.
Jonas Czech
  • 4,047
Try mkfs.vfat.
Assuming your pendrive is /dev/sdb
sudo mkfs.vfat -I -n "Name you want" /dev/sdb
will create a new FAT32 filesystem on /dev/sdb. (If you want NTFS, replace mkfs.vfat with mkfs.ntfs)
Explanation of -I:
-I creates a filesystem on the entire /dev/sdb device, removing any previous partitions.
From man mkfs.vfat:
-I  It is typical for fixed disk devices to be partitioned so, by default, you are not permitted to create a filesystem across the entire device.  mkfs.fat  will  complain  and  tell  you  that  it  refuses  to  work.  This is different when using MO disks.  One doesn't always need partitions on MO disks.  The filesystem can go
    directly to the whole disk.  Under other OSes this is known as the 'superfloppy' format.  This switch will force mkfs.fat to work properly.
I finally managed to solve the problem. It's quite easy once you gain the basic understanding. The main thing is that in Linux you should never use graphical user interface and always stick with terminal. I did the following in terminal:
sudo su
This makes me sudo user by default without the need to put sudo at first everytime
fdisk -l
This checks for the present disks. Thus I can safely determine my pendrive to be sdb. dd is destructive command and has to be carefully used against correct drive
This overwrites the entire disk with zeros. It wipes all present file systems and partition tables. The disk at this point is useless.
parted /dev/sdb
This starts the parted program which is a powerful CLI program to create partition tables
mklabel gpt
This creates gpt partition table for the disk
quit
This quits parted program
mpunt -a
After altering or creating a new partition table /etc/fstab has to be reloaded. This can be done by rebooting the computer. However this one line terminal command also does the same job
umount /dev/sdb
Now in order to create partitions of different file systems /dev/sdb has to be unmounted first
mkfs -t ext4 -L SANDISK /dev/sdb
This creates file partition of type ext4. Here -t argument is for file type. -L argument is for the label of the disk. Here the disk is named 'SANDISK'
That's it
rancho
  • 4,136
