This is quite exciting, my first post on ask Ubuntu.
Initially, the Wifi was working and then an update was pushed(I apologize, I don't remember the update that affected it) and for some reason, the Wifi only worked every now and then or seemed like the signal was very weak. I did my best to try and solve the issue by searching several hundred resources for the right answer and I got as far as trying to setup wpa_gui and the proper source to run it.
So, unfortunately I now do not receive any indication that networks are being picked up by the wireless adapter or anything. I also attempted to do a fresh install of Xubuntu to try and fix the issue but I also cannot get to my BIOS to set up booting from the MicroSd like I had installed it with.
I apologize if this is a noobish question but I really do need some help. If there are any pros out there that could walk through this lend me a hand I'd greatly appreciate it.
In case it is needed the PC is the Microsoft Surface Pro Gen 1 128GB.
Thanks in advance and I'll be watching out for a reply.
Hizqeel
  • 1,915
  • 28
  • 24
  • 24
Connect device to an ethernet
     sudo apt-get install git
git clone https://github.com/kvalo/ath10k-firmware.git
sudo cp -r ath10k-firmware/QCA9377 /lib/firmware/ath10k/
sudo cp /lib/firmware/ath10k/QCA9377/hw1.0/firmware-5.bin_WLAN.TF.1.0-00267-1 /lib/firmware/ath10k/QCA9377/hw1.0/firmware-5.bin
Reboot You do not need Windows drivers and ndiswrapper This has been recently fixed upstream, follow the instructions to install the backported modules and needed firmware
sudo apt-get install build-essential linux-headers-$(uname -r) git
echo "options ath10k_core skip_otp=y" | sudo tee /etc/modprobe.d/ath10k_core.conf
wget https://www.kernel.org/pub/linux/kernel/projects/backports/stable/v4.4.2/backports-4.4.2-1.tar.gz
tar -zxvf backports-4.4.2-1.tar.gz
cd backport-4.4.2-1
make defconfig-wifi
make
sudo make install
And it should work after a reboot It will fail when a new kernel is installed through updates until the kernel is patched to support the wifi. When that happens you will need to
cd backports-4.4.2-1
make clean
make defconfig-wifi
make
sudo make install
And reboot
Source: Qualcomm Atheros Device [168c:0042] (rev 30) Wi-Fi driver installation
Hedwig
  • 31
